Stand: 17.10.2017
Kein Touch
iPhone 5s/5C/6/6+/SE (Touch IC)
Meson*– 343S0694
Cumulus -*BCM5976
Touch to Proximity Sensor Chip – U2403
iPhone 6S/6S+ (Touch IC)
pp1v8_Touch Filter (240 Ohm, 350mA, 0201)
iPad Pro 12.9
Touch Filter (240OHM-350MA 0201)
Kein Aufladen (vielleicht auch no Power)
iPhone5s/5C/6/6+/SE/6S/6S+/7/7+ & iPad Air/Air 2
[URL=“http://s.click.aliexpress.com/e/JQzRfea”]610A3BTristar (U2 IC, U1700, U4500)
1610A3 bis iphone 6S
SN2400B0(Tigris — USB Charging IC)
iPhone 5 & iPad 3/4
1608A1 - U2
Keine Hintergrundbeleuchtung
iPhone 5/5s/5c/SE
Backlight Filter – 240-OHM-0.2A 0201
Backlight Diode* – (20V)
iPhone 6
Backlight Filter – 240-OHM-0.2A 0201 (FL2024, FL2025, Fl2026)
Backlight Capacitors (C1505, C1530, C1531)
Backlight Diode (D1501 – 30V)
Backlight Coil (L1503)
Backlight IC (U1502)
iPhone 6+
Backlight Filter – 240-OHM-0.2A 0201 (FL2046, FL2025, Fl2026)
Backlight Capacitors (C1505, C1587)
Backlight Diode (D1589 – 20V)
Backlight Coil (L1503, L1589)
Backlight IC (U1502, U1580)
iPhone 6s/6s+
Backlight Filter (240OHM-350MA 0201)
Backlight Capacitor (C4023 & C 4053 – 10uf 35V 0603)
Backlight IC (U4020 & U4050 (6S/6S+/7/7+))
Backlight Diode (D4021 & D4051)
Backlight Diode (D4020 & D4050)
Backlight Coil (L4020 & L4050 – 15UH-20%-0.72A-0.9OHM)
Backlight Coil (L4021 & L4051 – 1.0UH-20%-3.6A-0.060OHM)
iPhone 7/7+
Backlight Filter (33Ohm-1500mA 0201)
Backlight IC (6S/6S+/7/7+)
iPad Mini 1/2/3/4
Backlight Filter (L2200 – 240 ohm 300MA 0402)
Backlight Diode (40V 1Amp)
iPad 3/4
Backlight Filter (240ohm 300mA 0402)
Backlight Diode
iPad Pro 12.9
Backlight IC
Kein Bild (schwarz)
iPhone 5C/5S/SE/6/6+/6S/6S+/7/7+
Chestnut – Display Driver
iPhone 6/6+
C5202_RF*(10uF 6.3V 0402)
iPhone Connector
iPhone 5 Connectors
iPhone 5S/SE/5C Connectors
iPhone 6 Connectors
iPhone 6+ Connectors
iPhone 6S Connectors
iPhone 6S+ Connectors
iPhone 7 Connectors
iPhone 7+ Connectors
iPad Mini 1/2/3/4 Connector
Digitizer Connector
LCD Connector
iPad 2/3/4 Connector
Digitizer connector
LCD Connector (ipad 3/4)
Pry Damage
iPhone 5 Kein Home Button – Kein*Power Button
Q3 + U3 + DZ101_RF
iPhone 5 – Ladekapazität ändert sich nicht
FL10/Fl11 (120 ohm 210mA 01005)
C273, C279, C9 (56pf 16V 01005)
C277 (100pf 16V 01005)
iPhone 5C/5S
FL11 (120 ohm 210mA 01005)
C23, C25, C279, C22, C9 (56pf 16V 01005)
C275 (220pf 10V 01005)
iPad Mini
Fl7500 (240 ohm 200mA 0201)
C7522, C7623 (33pf 16V 01005)
C7525 (27pf 16V 01005)
Diverse Chips
iPhone 6/6+ Camera LDO U2301
iPhone 6/6+ Touch ID LDO U2100
iPhone 6S Common VCC_Main Caps (15uF 6.3V*0402)
iPhone 6S Common Cap (10uF 10V 0402)
iPhone 6S Common Cap (2.2uF 6.3V 0201)
iPhone 5/5C/5S/6/6+/6S/6S+ Common Filter (120ohm 210mA 01005)
Bootloop
Aliexpress Verkäufer die nicht zu empfehlen sind
Verkaufen teilweise reballed Chips
Verkäufer die zu Empfehlen sind (eigene Erfahrung)
Smartphone Repair Parts
Jestar
Mobile Phone Repair Parts
Lucky Zoom (Mikroskope)
Wozniak ( Lötzubehör / Kleinteile / Pinzetten usw.)
Wer gute/schlechte Verkäufer auf Alliexpress kennt bitte mir eine kurze PN schicken.
Im Anhang noch Bestellnummern von Digikey und Mouser vom Markku … werde wenn ich es schaffe diese auch noch einzeln verlinken
