oder
https://de.banggood.com/MUSTOOL-G600-600X-Electronic-USB-Microscope-Digital-Soldering-Video-Microscope-Camera-4_3-Inch-LCD-M-p-1337353.html?rmmds=buy&cur_warehouse=CZ
oder
https://de.banggood.com/Andonstar-ADSM302-Long-Object-Distance-Digital-USB-Microscope-For-Mobile-Phone-Repair-Soldering-Tool-p-1232954.html?rmmds=buy&cur_warehouse=UK
Lötstation
https://www.rexcom.de/jbc-loettechnik/loetstationen/3553/jbc-loetstation-cd-2sqe-t210-loetkolben?c=351
Heißluftstation
Ebay: Quick 861DW (ca 350.-€)https://www.ebay.de/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR1.TRC0.A0.H0.Xquick+861+DW.TRS0&_nkw=quick+861+DW&_sacat=0
China:Quick 861DW
https://www.aliexpress.com/af/quick-861DW.html?SearchText=quick+861DW<ype=wholesale&d=y&tc=main&blanktest=0&initiative_id=SB_20171121010552&origin=n&catId=0&isViewCP=y&aff_request_id=828755ce3b4d4d6d8908607c435659f3-1580303930531-00891-niYZ3zv&aff_platform=link-c-tool&cpt=1580303930531&sk=niYZ3zv&aff_trace_key=828755ce3b4d4d6d8908607c435659f3-1580303930531-00891-niYZ3zv&terminal_id=67363b32230f4e4598d51bfb9d682805
oder die Luxusklasse JBC (Herrn Fink fragen ca. 1500.-€) Alternativer Shop: Rexcom.de
https://www.jbctools.com/tese-precision-hot-air-station-product-1255-category-3-menu-1.html
Ipower max für iphone 6g 6s 6sp 6p 7 7p 8 8plus x XS MAX handy Reparatur Power versorgung Boot Kabel Batterie Schaltung schutz
https://de.aliexpress.com/item/32839810874.html?scm=1007.22893.153997.0&pvid=aa36339f-7f1b-4eee-85db-b677f14bedc0&onelink_page_from=ITEM_DETAIL&onelink_item_to=32839810874&onelink_publisherid=171733914&onelink_memberseq=0&onelink_duration=1.906475&onelink_status=noneresult&onelink_item_from=32839810874&onelink_subid=NULL&onelink_page_to=ITEM_DETAIL&aff_request_id=b3db7b67730a4020996da68df4002ea2-1580303699932-04067-MNfEE6y&aff_platform=link-c-tool&cpt=1580303699932&sk=MNfEE6y&aff_trace_key=b3db7b67730a4020996da68df4002ea2-1580303699932-04067-MNfEE6y&terminal_id=67363b32230f4e4598d51bfb9d682805
1. Lötpaste (für IC reballing) und Lodraht 0,3mm (Bleihaltig, niedriger Schmelzpunkt von ca. 183 Grad)
Lötpaste PPD 183 https://www.rexcom.de/werkstatt-werkzeug/loeten/3689/ppd-183-lotpaste-50g?c=90
Lotdraht https://www.rexcom.de/werkstatt-werkzeug/loeten/3736/mechanic-hx-t100-loetzinn-0.3mm?c=159
Keine bleifreie Lötpaste/Lötzinn verwenden. Da hier der Schmelzpunkt deutlich höher liegt. Eine Ausnahme ist Lötdraht und Paste mit Bismuth z.B. diese hier:
2. Flußmittel: Am besten sind "no clean" Flußmittel wie z.B. Amtech 559
https://microsolderingsupply.com/amtech-559-No-Clean-Tacky-Flux-10cc
https://www.rexcom.de/werkstatt-werkzeug/loeten/3307/amtech-flux-flussmittel-10ml
3. Entlötlitze 2,0 und 1,5mm und 1,0mm breit:
https://www.rexcom.de/werkstatt-werkzeug/loeten/3720/goot-wick-entloetlitze-2mm-in-flussmittel-getraenkt?number=D3005
https://www.rexcom.de/werkstatt-werkzeug/loeten/3760/goot-wick-entloetlitze-1.5mm-in-flussmittel-getraenkt?number=E1010
https://www.reichelt.de/entloetlitze-kupfer-1-6-m-x-1-mm-ell-fe-00-p7388.html?&trstct=pol_0
Diese wird zuerst mit Flußmittel eingerieben und danach gehts ans entlöten.
4. Für eure Gesundheit: Eine Lötdampfabsaugung.
http://www.di-li.eu/ldas900.html
5. TIP TINNER:*
Sehr hilfreich bei Lötspitzen die kein Lötzinn mehr annehmen wollen bedingt durch oxidation. Einfach die heiße Lötspitze kurz reintauchen und danach ist diese wieder bereit für neue Lötungen. Eine Dose reicht ein halbes Löterleben * *
Und nach getaner Lötarbeit oder längeren Pausen eure Spitzen immer mit etwas Lötzinn verzinnen. Danach nicht abstreifen sondern so lassen und ausschalten.
https://www.reichelt.de/Loetspitzenreingung/EDSYN-CT-1/3/index.html?ACTION=3&LA=517&ARTICLE=32675&GROUPID=4133&trstct=dnrtcl_ldsldr
6. Chip Quik:*
Niedertemperaturlot mit einem Schmelzpunkt um die 100 Grad *:shock: *Benutzen manche zum auslöten von z.B. USB-Buchsen oder um die hitzeempfindlichen Konnektoren am Iphone aus/einzulöten. *
https://www.digikey.de/product-detail/de/chip-quik-inc/SMD1/SMD1-ND/304148
9. Kapton oder PTFE Klebeband hitzebeständig bis ca. 350 Grad:
Ergänzend wird gerne Aluminium Klebeband genommen. Oder mit ausgelöteten EMI-Shields gearbeitet um die Hitze von anderen Bauteilen fernzuhalten.
https://www.rexcom.de/werkstatt-werkzeug/verbrauchsmittel/3721/kapton-band-2cm?number=G5001
https://www.rexcom.de/werkstatt-werkzeug/verbrauchsmittel/3726/hitzebestaendiges-ptfe-klebeband-2cm-teflon?number=G6002
10. ESD Pinzette: Nicht die ganz billigen kaufen - die klaffen meist an den Spitzen etwas auseinander. Und wenn man SMD Bauteile und BGAs präzise positionieren will - braucht man gutes Werkzeug. ESD-Schutz brauchen wir, glaube ich nicht mehr diskutieren...Auch benutzen sollte man die ESD-Handschuhe. Nicht nur wegen ESD-Stress der Bauteile. Auch als Hitzeschutz für die Hände, bei arbeiten mit der Vorheizplatte.
https://www.ersa-shop.com/pinzetten-speziell-f%C3%BCr-smdtechnik-esdausf%C3%BChrung-c-212_221.html?osCsid=oq1hv2k7i12mk9fqbc285e9lq6
11. SMD-Kleber: Wer zum Schutz Bauteile festkleben will - nimmt sowas.
http://de.rs-online.com/web/p/warmeleitkleber/1181368/
12. ESD-Pinsel: Zum reinigen von Flußmittelresten, Korrosion von Wasserschäden oder bei der "lange Schraube in Logicboard" Reparatur. Die Borsten des Pinsels etwas mit der Schere kürzen - dann ist die Reinigungswirkung besser.
https://www.weidinger.eu/shop/search/0?q=esd+pinsel
13. Glasfaserstift: Zum Reinigen von Lötpads/Bauteilen von Brandspuren und Korrosion !! Äußerste Vorsicht - nicht mit zuviel Druck arbeiten !!
https://www.voelkner.de/products/47428/Glasfaserradierer-4mm-Incl.-12-Pinse.html?ref=43&products_model=C77591&gclid=EAIaIQobChMI5Y-wyrjA1wIVUbobCh01lQ5OEAQYASABEgLaufD_BwE
14. Solder Mask (Lötstopplack) Zum nachträglichen isolieren an PCBs. Ideal für Reparaturarbeiten.
https://www.rexcom.de/werkstatt-werkzeug/loeten/2213/mechanic-uv-curing-solder-mask-gruen?number=G1007
Zur Aushärtung des Lacks wird eine UV-Lampe (vorzugsweise mit 365nm Wellenlänge) benötigt.
https://www.rexcom.de/werkstatt-werkzeug/refurbishing/3347/uv-lampe?number=G7002
15. Reinraum Tücher
https://de.aliexpress.com/item/iRepair-You-200PCS-Pack-Mobile-Phone-New-Soft-Cleanroom-wiper-cleaning-Non-Dust-Cloth-Dust-Free/32820892832.html?spm=a2g0s.9042311.0.0.27424c4dQ8Ysu7
Reballing Folien
https://de.aliexpress.com/item/32951541887.html?spm=a2g0o.productlist.0.0.707965c5jsqylS&s=p&algo_pvid=6bde050d-86c5-47dc-96ce-e37191bf7782&algo_expid=6bde050d-86c5-47dc-96ce-e37191bf7782-0&btsid=d7de00a1-a2e0-4eec-bb3b-511029a328cd&ws_ab_test=searchweb0_0,searchweb201602_1,searchweb201603_53
https://de.aliexpress.com/item/4000329619416.html?spm=a2g0o.productlist.0.0.707965c5jsqylS&algo_pvid=6bde050d-86c5-47dc-96ce-e37191bf7782&algo_expid=6bde050d-86c5-47dc-96ce-e37191bf7782-13&btsid=d7de00a1-a2e0-4eec-bb3b-511029a328cd&ws_ab_test=searchweb0_0,searchweb201602_1,searchweb201603_53
https://german.alibaba.com/product-detail/bga-chip-reballing-rework-kits-for-xbox-and-ps4-bga-reballing-station-60719656390.html?spm=a2700.galleryofferlist.0.0.6bc2430fTskpab
https://german.alibaba.com/product-detail/ps4-stencil-cxd90026g-for-play-station-cpu-chip-reballing-reballing-station-stencils-1921418135.html?spm=a2700.galleryofferlist.0.0.6bc2430fTskpab
Ajo. Das erste Mikroskop ist geeignet. Die anderen ist Spielzeug. Du brauchst ein Stereo Mikroskop um die Tiefe einschätzen zu können und mit Barlow Linse einen ausreichenden arbeitsabstand zu haben.
das chipquik Zeug kannst dir sparen. Wenn du eh ppd Paste bestellst, bestellst einfach die 138er auch mit. Wenn du die mit dem vorhanden. Lot mischst, setzt du den Schmelzpunkt auch unter 138grad herab.
